Processors
14533 Discussions
Is there a real 1.5TB RAM configuration with XEON Platinum CPUs?
ESIWO
The discussion title is my question: Is there a real 1.5TB RAM configuration with XEON Platinum CPUs?
Which board supports that amount af memory? What type of RAM is necessary? Is a HCL existing?
Hi VASQU3Z,
I understand you need memory capacity confirmation for the Intel® Xeon® Platinum. Let me help you on this matter.
I can confirm the following processor supports 1.5TB of memory at DDR4-2666
https://ark.intel.com/products/120505/Intel-Xeon-Platinum-8176M-Processor-38_5M-Cache-2_10-GHz https://ark.intel.com/products/120505/Intel-Xeon-Platinum-8176M-Processor-38_5M-Cache-2_10-GHz
You may need to copy and paste this link on a separate window.
For compatible motherboards you need to check the link for compatible products
Hope it helps.
Allan J.
Hi VASQU3Z,
I wonder if you were able to address this matter with the information available on ark.intel.com
Allan J
