Community
cancel
Showing results for
Search instead for
Did you mean:
ВГеор
Is using single e5 2640 v3 possible?
Is there any problems? May i use it on two-sockets motherboard and one-socket motherboard with equal performance?
Community Manager
Hello Vitaly_cdnm,
I understand that you would like to know if there are any problems when using a single Xeon* processor in a dual-socket motherboard, regarding this there are different factors that must be taken into consideration.
First, you need to check the model of the motherboard in question and contact the motherboard's manufacturer to see if the dual-socket unit supports a single processor. If it does then that means that the motherboard will boot and work properly with only one.
Second however, if it does work with the processor you need to take into consideration the difference between the specifications of the dual-socket motherboard vs the single-socket one. This will tell the difference between the performance in each.
David V
Community Manager
Hello Vitaly_cdnm,
I am following up with your case and see that we have not heard back from you.
If you need more assistance do not hesitate to reply.
David V
ВГеор
Dear David
Thank you very much! Is your statement right for all the xeon e5 processors?
There is no one of them which must work in pair?
Community Manager
Hello Vitaly_cdnm,
Thank you for your response,
That is correct, any Xeon* processor should work properly. They do not need to work in pairs, that is only if you want to have a dual-processor but it is not necessary.
Hope you find this helpful.
David V
ВГеор
Dear David
Thank you very much! This is the answer i was looking for!
Additionally i have one more question, and would appreciate if you help
Could there be such a situation that program developer (or vendor) has a strict requirement for the server - that it should have exactly two processors, other way their program product would not work? Or they are wrong, and the correct requirement is, for example, that server should have some amount of processors operating at some frequency?
Community Manager
Hello Vitaly_cdnm,
I would not be able to tell as those are third party applications and it is up to set the requirements to use said software or program.
I apologize for not having the information.
David V
