Processors
14539 Discussions
It is okay for CPU to reach 90+ C?
Techguy45
In the past couple of days I monitor my CPU temperature and when it on heavy work load like redering, the CPU temp go beyond 80 or sometime even 90 degree celsius.
Is this kind of normal? or I need to change any of my hardware?
n_scott_pearson
You should replace it when you start to see your average idle temperatures rising or loaded temperatures reaching close to Tjmax (~100c)
AlHill
you have told us nothing.
So we can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
Doc
LeonWaksman
You didn't mentioned what CPU you are using. However, I can confirm that usually the maximum permissible CPU junction temperature is 100 C. So, 80-90 Deg C under heavy load seems to be normal.
Leon
Techguy45
I'm using i5-8400 for about 3 years
I have been reading about the thermalpaste, how often do I need to replace it? and will it reduce my cpu temperature? I never replace it since I got this PC.
Thanks for the helps
n_scott_pearson
Techguy45
Any recommended thermalpaste? Found a lot of brand when I'm searching on internet.
AlHill
btimofte
In 100% full load on all cores is OK , specially in a closed case. If it gets close to 99degrees you need to take measure , like 95+ degrees since it will throttle
