Processors
Processors (Intel® Core™, Intel® Xeon®, etc); processor utilities and programs (Intel® Processor Identification Utility, Intel® Extreme Tuning Utility, Intel® Easy Streaming Wizard, etc.)
12436 Discussions
J5005の最大メモリサイズ
KMats20
仕様書では、J5005​の最大メモリサイズは8GBとなっています。
これは間違いだと思います。
32GBを認識している画像も見つかります。
また、ASRockのJ5005-ITXのサポートメモリにも16GBのメモリが記載されています。​
Alberto_R_Intel
KMats20, The real specification of the Intel® Pentium® Silver J5005 is that it supports 8GB of RAM, as you can confirm in the link provided previously. The reason why it does not support a higher amount of RAM is because a design/market decision, most of the times you will find these type of processors in mobile devices like laptops or notebooks that were manufactured to work with regular applications on a daily basis, like for example in schools. Regards, Alberto R. Intel Customer Support Technician Under Contract to Intel Corporation
RAJU2529
New Contributor III
I checked both the intel and asrock website , I found in the both pages, maximum memory capacity is 8GB only
https://ark.intel.com/products/128984/Intel-Pentium-Silver-J5005-Processor-4M-Cache-up-to-2-80-GHz-
https://www.asrock.com/MB/Intel/J5005-ITX/index.asp#Specification
KMats20
インテルが8GBと記載したから、ASRockも8GBと記載したのでしょう。
でも、下記のメモリーリストを見てほしい。
https://www.asrock.com/mb/Intel/J5005-ITX/index.asp#Memory
​8GB以上のメモリがたくさん記載されているでしょう。
 最近のCPUの最大メモリサイズが8GBだなんておかしいと思いませんか。
もし、意図して8GBと記載しているなら、その理由を知りたいです。​
Alberto_R_Intel
KMats20, I just wanted to check if you were able to find the information you were looking for or if you still need further assistance with this matter? Regards, Alberto R. Intel Customer Support Technician Under Contract to Intel Corporation
KMats20
I have not got the information I wanted yet. So I need further assistance with this matter.
I need real specification of J5005. It is obvious that the J5005 recognize over 8GB memory.
And It seems strange that the maximum memory of the recently created CPU is 8 GB.
Does Intel intentionally set the maximum memory to 8 GB? What is the reason?
Alberto_R_Intel
