Processors
13562 Discussions
Just finished a build with i9 processor, and a new motherboard. No boot and the error code is 00. No bent pins under the processor. Removed and re-seated the processor. Still no boot. Suggestions?
BButl7
AlHill
Whose motherboard?
Are you at the correct bios?
Is the processor supported?
Have you contacted the motherboard manufacturer? Or, are we just assuming the board is good and it must be the processor that is bad?
Doc
BButl7
Rog Maximus XI Wi-Fi. It doesn’t start a boot so bios is never loaded. Yes I spoke to asus and they said take out processor and check for bent pins. Saw this on the processor- when viewed straight on it looks perfect but at the right angle it looks like there is some defect
AlHill
Often, the board will require a bios update with an older processor to get it to the proper bios level for the new processor.
That is the path I would take with the board manufacturer.
At a minimum, you should be able to determine what bios came with the board.
Doc
