Processors
16297 Discussions
KabyLake PCI Express Root Port # 10 - A2B1
TVent1
Windows 10 me detecta el siguiente problema:
¿Es grave? ¿Como puedo solucionarlo?
Tengo un i7 7700 y una placa base B250M GAMING PRO de MSI
n_scott_pearson
Reinstall latest Intel Chipset Software (INF Update) package, available here: https://downloadcenter.intel.com/download/20775/Intel-Chipset-Device-Software-INF-Update-Utility-?product=1145 Download Intel® Chipset Device Software (INF Update Utility)
Hope this helps,
TVent1
n_scott_pearson
If you go into Device Manager, right-click on the entry and select Update Driver, what happens? What does it say?
TVent1
I already have the last update
n_scott_pearson
CD (change directory) to the folder containing the files that you extracted from the ZIP file and run the executable using command line "setupchipset -overall".
Hope this helps,
