Processors
14534 Discussions
KabyLake PCI Express Root Port # 10 Error
CPool3
I am looking for a link to intel(r) 200 series chipset family thermal subsystem -a2b1 as it seems to be the only possible solution to the KabyLake PCI Express Root Port # 10 problem I have not yet tried. If someone could just make intel and msi find a solution to the problem of which there are many threads already it would save the customers a lot of trouble and time. I am encountering many bluescreens "memory management", critical process died", "page fault in nonpaged area"' among others.
I have tried reinstalling windows, checked all hardware to make sure everything is properly connected, as well as all solutions for the driver issue other than the one stated above.
My specs are:
Intel Core 15-6500 CPU
MSI Tomahawk Arctic 270
AMD Radeon R9 200/HD 7900
Whocrashed:
On Sat 25/11/2017 22:31:11 your computer crashed
crash dump file: C:\WINDOWS\Minidump\112517-21312-01.dmp
This was probably caused by the following module: http://www.google.com/search?q=ntoskrnl.exe ntoskrnl.exe (nt+0x1640E0)
Bugcheck code: 0x139 (0x3, 0xFFFFEE86DB736B70, 0xFFFFEE86DB736AC8, 0x0)
Error: http://www.google.com/search?q=MSDN+bugcheck+KERNEL_SECURITY_CHECK_FAILURE KERNEL_SECURITY_CHECK_FAILURE
file path: C:\WINDOWS\system32\ntoskrnl.exe
product: http://www.google.com/search?q=Microsoft%C2%AE%20Windows%C2%AE%20Operating%20System Microsoft® Windows® Operating System
company: http://www.google.com/search?q=Microsoft%20Corporation Microsoft Corporation
description: NT Kernel & System
Bug check description: The kernel has detected the corruption of a critical data structure.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
crash dump file: C:\WINDOWS\memory.dmp
This was probably caused by the following module: http://www.google.com/search?q=ntfs.sys ntfs.sys (NTFS+0x1B02E)
file path: C:\WINDOWS\system32\drivers\ntfs.sys
description: NT File System Driver
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
On Sat 25/11/2017 22:18:03 your computer crashed
crash dump file: C:\WINDOWS\Minidump\112517-22281-01.dmp
This was probably caused by the following module: http://www.google.com/search?q=ntoskrnl.exe ntoskrnl.exe (nt+0x9590E)
Bugcheck code: 0x1000007E (0xFFFFFFFFC0000005, 0xFFFFF8035A53190E, 0xFFFF9B82AF0A9AF8, 0xFFFF9B82AF0A9340)
Error: http://www.google.com/search?q=MSDN+bugcheck+SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M
Bug check description: This indicates that a system thread generated an exception which the error handler did not catch.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
XXXWHITES...
Hello /thread/119900 Pooligan,
Please stay in your original thread: /thread/119900 https://communities.intel.com/thread/119900
Amy C.
