Processors
14668 Discussions
Kinda of a stupid question, but is it safe to remove Intel drivers like Rapid storage technology or Management engine components?
AHold5
I recently got a new CPU that is not intel (Ryzen 5), but ive been experiencing constant and unexpected crashes related to memory management (based off the errors the Windows blue screen gave me).
I am still trying to figure out the cause of the crashes, but old Intel drivers might be the cause and I am wondering if these are safe to remove since I am no-longer running an Intel chip, or are these still important?
n_scott_pearson
Yes, you can remove these drivers. I don't think that this will make a difference, however. You really should reinstall the O/S from scratch if you have made hardware changes this dramatic (processor, chipset, motherboard, etc. all changed).
Hope this helps,
n_scott_pearson
Hope this helps,
AHold5
Thank you. I thankfully have a second drive that I can just dump everything of mild importance to me onto just incase the reinstall decides to mess with things (it's happened to me in the past. all of those accidental ksp screenshots because the screenshot key is the same as the aerodynamics key...) but before I do that i'll see if just removing the old intel software will do the trick.
