Processors
14780 Discussions
L5630 Idle Power Usage?
I can't find any good reviews on this. If I have a single L5630 with a pretty typical mother board, 1 stick of 1.3 v ram and no hard drives; how much power usage should I expect when system is completly idle?
Just looking for a ball park firgure. I've seen everything from ~25 watts to ~235 watts; but don't put to much faith in either of those.
Anyone own one of these? I'd like to see what a kill-a-watt makes of it.
Vegan
At its lowest the CPU can downclock to < 10W when its idle.
A disk uses 10W, motherboards are about 100W or so.
wow! Thanks for the reply, that's amazing.
Why does the motherboard take up so much power?
Would using 1.3V memory (instead of 1.5V) lower by a noticable amount?
Vegan
Motherboards have a lot of devices on them, while each is low power, the sheer number of things adds up.
