Processors
16155 Discussions
LGA2066 Skylake-X Socket Pin Map for damaged socket repair
vinaypundith
I'm looking for a pin map / something that shows what areas of the LGA2066 socket correspond to what group of signals. I've scoured the internet for a bit already, couldn't find one for 2066 (found this for LGA115x and 2011 but not 2066). Can someone help me find this?
I have an X299 motherboard that had several pins bent on the socket that I'm trying to fix. I've straightened what I can see, and it does boot up but does not detect any RAM sticks on memory channel B. I'm trying to figure out what part of the socket I need to be inspecting closer, since the pins all look okay to my eyes. (I'm using a Core i9 7900X CPU)
Thanks!
Zappa_RCC
Hi did you find the pinout for Lga 2066 Socket? i have the same problem i can not get DDR4  Quad channel working, . i have som bent pins aswell.
Sincerely  Per
vinaypundith
I didn't manage to find a pin map, but I did get my motherboard working-ish. I straightened the pins as best as I could with a dental pick, but it still didn't pick up the 4th memory channel (it picked it up once, and then not again). Once I bolted the cooler on, though, it started working. I guess the mounting pressure of the cooler made it touch just enough to pick up that last memory channel. Best of luck with fixing yours!
