1.I have taken muchcare while searching online and gathering accurate information about the latest windows 10 updates for v1803 edition
2.Before downloading files, temporarily disable windows defender or any their third party antivirus products
3.Make sure you connected with constant hgh speed internet, minimum internet connectivity speed atleast 256KB per second
4.Close all running applications
5.Use internet download manager for downloading files , make sure its should have feature resuming files
6.once downloading completes means ,
try below methods
connect the internet , open cmd , run as admin
type below each commands in cmd and enter and wait to completes
Sfc /scannow
Dism.exe /Online /Cleanup-Image /AnalyzeComponentStore
if result is displayed Component Store Cleanup Recommended : Yes , then enter the command
Dism.exe /online /Cleanup-Image /StartComponentCleanup
restart the computer
once you restarted the windows , login with administrator rights, install downloaded windows updates
I am sharing directdownloading links from www.catalog.update.microsoft.com
list of below files links does not contains any malwares or trojans
may 2018 update KB4103721 build number 17134.48 compatible with windows 10 v1803
for 64 bit os
for 32 bit os
may 2018 update KB4100403 build number 17134.81 compatible with windows 10 v1803
for 64 bit os
for 32 bit os
june 2018 update KB4338548 build number 17134.83 compatible with windows 10 v1803
for 64 bit os
for 32 bit os
june 2018 update KB4284835 build number 17134.112 compatible with windows 10 v1803
for 64 bit os
for 32 bit os
june 2018 update KB4284848 build number 17134.137 compatible with windows 10 v1803
for 64 bit os
for 32 bit os
july 2018 update KB4338819 build number 17134.165 compatible with windows 10 v1803
for 64 bit os
for 32 bit os
july 2018 update KB4345421 build number 17134.167 compatible with windows 10 v1803
for 64 bit os
for 32 bit os
july 2018 update KB4340917 build number 17134.191 compatible with windows 10 v1803
for 64 bit os
for 32 bit os
august 2018 update KB4343909 build number 17134.228 compatible with windows 10 v1803
for 64 bit os
for 32 bit os
august 2018 update KB4346783 build number 17134.254 compatible with windows 10 v1803
for 64 bit os
for 32 bit os
september 2018 update KB4457128 build number 17134.285 compatible with windows 10 v1803
for 64 bit os
for 32 bit os
september 2018 update KB4464218 build number 17134.286 compatible with windows 10 v1803
for 64 bit os
for 32 bit os
september 2018 update KB445869 build number 17134.320 compatible with windows 10 v1803
for 64 bit os
for 32 bit os
october 2018 update KB4462919 build number 17134.345 compatible with windows 10 v1803
for 64 bit os
for 32 bit os
october 2018 update KB4462933 build number 17134.376 compatible with windows 10 v1803
for 64 bit os
for 32 bit os
november 2018 update KB4467702 build number 17134.407 compatible with windows 10 v1803
for 64 bit os
for 32 bit os
november 2018 update KB4467682 build number 17134.441 compatible with windows 10 v1803
for 64 bit os
for 32 bit os
december 2018 update KB4471324 build number 17134.471 compatible with windows 10 v1803
for 64 bit os
for 32 bit os
december 2018 update KB4483234 build number 17134.472 compatible with windows 10 v1803
for 64 bit os
for 32 bit os
I hope with this post , all intel users will get benefit
