Processors
14539 Discussions
Laptop Processor Upgrade ?
I'm looking at upgrading my laptops processor without having to upgrade the Motherboard.
This is what i'm currently running.
Are my only options to upgrade to the following, or will these not even work?
T7600
T5300
T5200
Anything with Socket M is physically compatable, if you want to be sure then look at the acer website and see if there was some higher spec'ed models in the range and get the processor from the top of the range system at the time.
check the socket. You also need to make sure the bios for the laptop can handle whatever you put in it.
I'd also check to see if the processor is soldered into the socket too. there are a number of laptops that you can't remove the processor from as well.
my laptop is acer aspire 4720,my processor is intel core 2 duo 1.5ghz,667mhz,my ram is 1gb ddr2 and i use window 7 ultimate,i really want change my processor laptop,but how i must know what processor suitable for my laptop??i hope someone can help me...
I am having the same question
i want to upgrade my processor to
Intel Core i7-720QM Clarksfield 1.6GHz 6MB L3 Cache PGA988 45W Quad-Core Mobile Processor
or any i5
my model is
Lenovo X200, 744988u
Anyone help will be greatly appreciated
