Processors
14952 Discussions
MSI - Lite Load BIOS setting and 13600k
Yeargie
I was wondering what level mode I should set the Lite Load at for stock voltages? Mine was by default at 12 which was to high. Thanks
DeividA_Intel
Hello Yeargie,
Thank you for posting on the Intel® communities. I understand that you need help setting the configuration in your BIOS for your Intel® Core™ i5-13600K Processor.
In this case, the motherboard manufacturer (MSI) is the one in charge of providing you with the recommended BIOS settings based on the processor supported by the board (Intel® Core™ i5-13600K Processor). I recommend you get in contact with MSI to confirm which voltage settings are recommended for your Intel® Core™ i5-13600K Processor.
However, Intel does not recommend changing the CPU voltage or frequency since this is considered overclocking and could damage the CPU and may void the warranty.
You can now learn more about overclocking in the following article:
https://www.intel.com/content/www/us/en/support/articles/000038213/processors/intel-core-processors.html
Please keep in mind that this thread will no longer be monitored by Intel.
Deivid A.
