Processors
All support for Intel NUC 7 - 13 systems has transitioned to ASUS. Read latest update.
14289 Discussions
Memória Ram/Ram memory
Thiago7828
i5 13600k suporta 5600mhz no ddr5 e 3200mhz no Ddr4
i5 12600k suporta 4800mhz no ddr5 e 3200mhz no ddr4
Só que tem video gringo do i5 12600k usando 3600mhz no ddr4 sem o overclock na memoria ram, eu gostaria de saber qual que a verdadeira capacidade maxima de mhz que o i5 de 13 e 12 geração suporta no ddr4 e ddr5
        Tradução/Translation
i5 13600k supports 5600mhz on ddr5 and 3200mhz on ddr4
i5 12600k supports 4800mhz on ddr5 and 3200mhz on ddr4
Only there is a gringo video of the i5 12600k using 3600mhz on ddr4 without overclocking the ram memory, I would like to know what the true maximum mhz capacity is that the 13th and 12th generation i5 supports on ddr4 and ddr5
n_scott_pearson
You have the maximum validated and supported speeds. Any higher speeds *are* considered overclocking.
