Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Memory Voltage For 8700
I am trying to sort out the components for a number of 8700 builds, but am confused about memory.
What is the default ( stock ) memory voltage for the 8700? I do not want overclocked voltages.
I am finding this a bit of a minefield because the memory manufactures are very vague about voltages and even motherboard manufacturers seem to wander between 1.2V and 1.35V.
n_scott_pearson
Super User Retired Employee
If your board takes DDR3 memory, then the voltage should be 1.35V (i.e. DDR3L).
If your board takes DDR4 memory, then the voltage should be 1.2V.
