Processors
14534 Discussions
Meu computador se tornou impossível de se usar normalmente graças a um problema que está me incomodando muito: USO DE ENERGIA NO MUITO ALTA SEM PARAR, COMO EU NUNCA VI ANTES E ISSO TRAVA
MFide
segue o vídeo: https://www.youtube.com/watch?v=NET7duIr5vU
eu pesquisei sobre e nunca vi nada antes, me ajude por favor
Amy_C_Intel1
Hello MFide, Thank you for posting on the Intel® Communities. When did this start? Do you have any issues using the computer? I believe that is a normal behavior, it's likely that the software needs it to work fine. If, you do not have any issues with your computer I would not worry about, it looks normal. Amy C Intel Customer Support Technician Under Contract to Intel Corporation
MFide
thank you
