WFERN3, Thank you for posting in the Intel® Communities Support.
Just to let you know, we only provide support in English language and currently, we are using a translation tool.
It is hard to tell for sure what is the source of Windows* showing BOSD randomly, it could be for many different factors, as you mentioned, it could be because of the Intel® Intel® Core™ i7-8750H Processor getting overheated.
Please make sure that the fans are working properly, that the notebook has good ventilation and reset the BIOS to defaults, if there is a BIOS update available please install it as well.
According to the specifications of the Intel® Processor, the t-junction temperature is 100°C, so any kind of temperature results that it is under that value is considered normal and expected:
https://ark.intel.com/content/www/us/en/ark/products/134906/intel-core-i7-8750h-processor-9m-cache-u...
We do have a tool called Intel® Processor Diagnostics Tool that is very reliable, it will do an overall test on the unit and if the Intel® Processor passed the test it means it is working properly, please install it and run it, once you get the chance please let us know the results:
https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool
Albert R.
A Contingent Worker at Intel
WFERN3, I just wanted to check if you saw the information posted previously and if you need further assistance on this matter?
Albert R.
Desculpe por demorar a responder.
Vi sim sua resposta. Instalei o Intel-Processor-Diagnostic-Tool e o CPU passou nos testes. Mas como a temperatura continuava alta, pesquisei mais a respeito do problema. Percebi que as reclamações do problema com meu notebook, Dell G3-3579, são constantes. Acredito que seja um problema de arquitetura desse notebook.
Instalei a ferramenta da Intel Intel(R)-Extreme-Tuning-Utility e reduzi as potências do Turbo Boost. Ruim que sempre que ligo o notebook tenho que fazer esse procedimento.
Fiz o teste com o software nativo da DELL e os coolers estão funcionando corretamente.
Você poderia me indicar algum software para que eu limite o Turbo Boost permanentemente? Se deixar ele operar naquelas temperaturas elevadas logo o notebook morre.
Mesmo temdo reduzido as potências do Turbo Boost, no Intel(R)-Extreme-Tuning-Utility fica constante (90% do tempo) o alerta de Power-Limit-Throttling (YES).
You should note that XTU does not support your processor. Only X and K processors are supported, not H.
Doc
Não tinha reparado esse detalhe. Agradeço pela observação!
