Processors
16099 Discussions
Minimum processor state in power plan
Rishav
Hi All
What will the minimum processor state do if we set to 5% in balanced power plan(Which is already set)
1. Will the CPU lower the Power & Voltage to 5% when its Idle?
2. Will it affect under heavy load. I heard setting the 5% min state will affect the performance regardless of 100% max processor state?
3. Will minimum processor state will be active when CPU will be under load for heavy application?
And in High/Ultimate power plan, Why the CPU min state is set to 100% by default.
1. Will power and voltage always be at 100% if the CPU is at idle?
I just want to know in details. When should we set min processor 5% and 100%? In which scenario? Do we really need min processor state to 100% (even while playing games)
I guess it will increase just electricity bill regardless of no performance boost
MY BUILD: Core i7 9700K, Noctua Noctua NH-U14S Cooler with 2 Fans, MSI Z390 Ace, G.Skill F4-3200C16Q-32GTZR x 4 , Seasonic PRIME TX-850 , Colorful RTX 3080 Ti NB-V, Cooler Master MB500 RGB, SAMSUNG 860 EVO 500GB, WD Green 120GB, 5x Nocuta NF-A14 iPPC-3000 PWM , Gigabyte Force K83, Razer Death Elite, Windows 10 Pro.
DeividA_Intel
Hello Rishav,
Thanks for your patience. I will respond to your questions:
1. Will the CPU lower the Power & Voltage to 5% when it is Idle?
  • A/ The default minimum processor state value in Windows 10 and 11 is 5%; however, Intel cannot confirm that will be a permanent number, it can fluctuate based on what your system is running (what is in the background)
2. Will it affect under heavy load? And, 3. Will the minimum processor state be active when the CPU will be under load for heavy applications?
  • A/ Numbers can vary and increase under a high workload.
4. Will power and voltage always be at 100% if the CPU is idle?
  • A/ There is no exact value that I can provide you for each processor. The processor has a few internal voltage regulations (FIVR, Digital Linear voltage regulator(DLVR) to support internal power rails. In each processor datasheet Technical Resources: Intel Core Processors there is a section called"electrical specifications" You can see average voltage ranges and specifications and understand how volts work on the CPU depending on different stages and based on Intel technology.
Bear in mind that these ranges will depend on system requirements and those are average based on tests, not necessarily exact values.
If you have any questions, please let me know.
Deivid A.
DeividA_Intel
Hello Rishav,
Thank you for the information provided
Deivid A.
DeividA_Intel
Hello Rishav,
Deivid A.
DeividA_Intel
Hello Rishav,
After checking your thread, I would like to know if you need further assistance.
If so, please let me know.
Deivid A.
DeividA_Intel
Hello Rishav,
I was checking your thread and see that we have not heard back from you.
I’m going to close your post, but if you need further assistance, please do not hesitate to create a new thread.
Deivid A.
