Processors
13560 Discussions
Moisture Sensitivity Level for E5-2618L v3
SHime
Does any one know what is the MSL for E5-2618L v3?
Thank you in advance.
JoseH_Intel
Hello SHime4,
Thank you for joining the Intel community
The moisture sensitivity level (MSL) should be indicated in the packaging material of the processor.
If you don't have it then according to the Xeon processor datasheet, ones the moisture barrier bag is open the device should be stored at relative humidity of no more than 60% @24 degree Celsius
https://www.intel.com/content/dam/www/public/us/en/documents/datasheets/8th-gen-processor-family-s-platform-datasheet-vol-1.pdf#page=121
Hope this helps
Jose A.
Intel Customer Support
JoseH_Intel
Hello SHime4,
Hope this helps
Jose A.
JoseH_Intel
Hello SHime4,
I am just following up to double-check if you found the provided information useful. If you have further questions please don't hesitate to ask. If you consider the issue to be completed please let us know so we can proceed to mark this thread as closed. I will try to contact you back on next Thursday 8th if not hearing from you by then. After that the case will be automatically closed.
Jose A.
