Dear Mr./ Mrs.
My 3337u CPU Test failed at 0.80026 Ghz while it should get 1.8 Ghz, how can I fix this?
I hope this can be fixed with an update of an driver.
Looking forward hearing from you!
Greetings Tim Jager
this is the outcome of the test:
--- Testing Processor 1 ---
--- IPDT64 - rev 2.10.0.0.MP ---
--- Start Time: 09/16/2014 16:39:24---
--- Skipping Config ---
--- Reading CPU Manufacturer ---
Expected --> GenuineIntel
Detected --> GenuineIntel
Found --- Genuine Intel Processor ---
--- Temperature Test ---
Temperature Test Passed!!!
Temperature = 44 degrees C below maximum.
--- Reading Brand String ---
Detected Brand String:
Intel Core i5-3337U 1.80GHz
Brand String Test Passed!!!
--- Reading CPU Frequency ---
Expected CPU Frequency is --> 1.80
Detected CPU Frequency is --> 0.80026
CPU Frequency Test Failed!!!
--- Test End Time: 09/16/2014 16:39:39---
System Information
Processor Name: Intel(R) Core(TM) i5-3337U CPU @ 1.80GHz
Processor Information: Intel64 Family 6 Model 58 Stepping 9
Number of Physical Cores: 2
Number of Logical Cores: 4
Installed System Memory: 8 GB
Operating System: Microsoft Windows 8.1 Single Language 64-bit
Graphics Information: Intel(R) HD Graphics 4000
System Product: NP540U4E-K01TH
System BIOS: P08ACM.065.140226.dg
FAIL
- Tags:
- CPU
Tim, I am sorry for the trouble.
Please reset your BIOS settings back to default.
If the issue persists I recommend you contacting the http://www.intel.com/support/oems.htm system manufacturer for assistance.
