Sounds like your processor cooling solution is not working properly. Look at:
- Fan is properly plugged into 4-pin motherboard header and spinning properly.
- Heatsink is properly attached to motherboard and tight against processor.
- Fan speed control programming in BIOS Setup is not mucked up (try resetting to BIOS defaults).
Hope this helps,
