Hello -
My HP machines with an Intel TPM is running firmware version 403.1.0.0. is failing to provision and unable to attest due to a missing EK certificate - how do I fix this issue?
Hello processor01,
I'll check on this query and I will post an update once it's available.
JeanetteC.
Hello processor01,
Greetings.
Kindly make sure the latest OS updates are installed, and try a fresh OS install. TPM is a service running on OS. Make sure TPM is enabled. https://support.microsoft.com/en-us/windows/enable-tpm-2-0-on-your-pc-1fd5a332-360d-4f46-a1e7-ae6b0c90645c
If further issues persist, I highly recommend contacting your system manufacturer support team for further assistance.
JeanetteC.
Hello processor01,
Let me know if you have any questions.
Jeanette C.
Hello processor01,
I have not received any response in the past few days. I hope that the recommendations I shared regarding the HP machine with an Intel TPM running firmware version 403.1.0.0. with missing EK, has helped.
I highly suggest contacting your system manufacturer support team for further assistance if the issue persists. I will now proceed to close this thread.
Sincerely,
JeanetteC.
