Processors
16430 Discussions
My I7 14700K instant thermal throtteling when ever is start a benchmark or stresstest
StanZ
Hello all,
I was recently testing my CPU to see what it can handle in Intel Extreme Tuning Utility. While I was testing, I saw something strange: my CPU temps instantly shoot up from 47°C to 100°C when I start the test and instantly drop from 100°C to 47°C-50°C when I stop the test.
I tried all the basics like tightening the CPU cooler screws, etc.
I also ran the Intel Processor Diagnostic Tool, and it passed all the tests. When I was doing this test, my CPU did not thermal throttle. It stayed at 95C.
The strange thing is, I have the same problem at work on a completely different PC with different specs.
Is it normal for a CPU to shoot up to 100°C during a benchmark or stress test and cool down immediately after? Or is it Intel's SVID behavior, 'Intel's fail-safe,' because of the instability issues that the 14th gen has? Or Could it be that there is a bottleneck issue between CPU and GPU
I came across a similar problem on Reddit, but I have yet to find the solution.
https://www.reddit.com/r/buildapc/comments/17mxsj2/i914900k_reaching_100%C2%BAc_and_thermal_throttling_12/
My specs
Asus Prime Z790-A Wifi
I7 14700KF
Artic cooler Liquid Freezer III 360
RTX 2060 Super
32 GB 6000MT/s
750W PSU
PC at work Specs
Aorus Master Z590
I9 11900KF
Be quiet Dark Rock 2 Cooler
RTX 3060
64 GB 3600MT/s
850W PSU
JainilJain
it is completely normal for the CPU to shoot to 100°C right at the beginning of a stress test because it takes a little time for your cooler to know that CPU is under load and it needs to ramp up the fans to cool it down. The thing to look for is if your CPU is stuck at 100°C for a while and you observe clocks dropping or are not stable. If any of those two happen then there might be some issue and you would need to troubleshoot. Otherwise its completely safe for the CPU to shoot straight to 100°C and after taking the load off the core temperatures to  plummet instantly to normal idle temperatures. Hope this helps you.
RobbieR_Intel
Hello StanZ
Thank you for reaching out and providing detailed information about the issue you're experiencing with your CPU temperatures. We appreciate your diligence in troubleshooting and sharing your observations.
Please answer the following questions:
  • When was the last time you changed your Thermal Paste?
  • Is there adequate airflow in your case? Are all fans operational and correctly oriented?
  • Is your BIOS up to date?
  • Did you overclock your Processor?
  • When did the issue start to persist?
We look forward for your response.
Robbie R.
StanZ
Thank you for your response and your time to help me.
    When I installed the news AIO cooler, that was around the time I made this post. Before this AIO cooler I had the Coolermaster hyper 212.
    All Fans are working and the air flow goes from bottom to the top the case I have is the coolermaster sl600m
    When making this post the bios I was running was PRIME Z790-A WIFI BIOS 1661 And now I am running 1663 this should have the micro code 0x129 fix
    I did not overclock my CPU and  the bios is on enforce all limits setting and the SVID behaviour is on intels fail safe
    I do not know when it started but when I installed my new cooler to test the temps that is when i noticed it. But I think it started when I upgraded 14th gen because on my i5 9600K I never had this issue
On the image you can see that the temps rise and drops in no time
(Virus scan in progress ...)
RobbieR_Intel
Hello StanZ,
Thank you for your detailed response and providing additional insights regarding the high CPU temperatures you observed during your testing with the XTU.
Please answer the additional following questions:
We look forward to your response!
Robbie R.
StanZ
Hello Robbie R
My bios is on Intels Default see attachements mabye there is a setting incorrect.
My PSU is a Coolermaster 750W MWE Gold
For the measuring software I used XTU and GPU Z to see the temps and for stress testing I used Cinebench multi core and single core and this website https://mprep.info/gpu/
The IMG is the bios settings
The Schermafbeelding is a screenshot of the temprature rising. Where the first part of this is 1 minute single core cinebench test and the temps go around between 60- 70c. When the temps rise to 100c it is a minute multicore test from cinebench.
Kind regards
Stan Z
CoolBook
Hello @StanZ
Here is a quick test to determine if your cooler is working as expected.
I have used plenty of LFII 360, but not the new version 3.
Let's assume that it will dissipate at least 200W easily when functioning properly.
1. Limit your CPU power consumption to 200W in BIOS.
2. Run the fans/pump at max.
3. Start a CB multithread test.
4. Monitor temperatures and max power consumption using HWInfo or ThrottleStop.
Something is wrong if your CPU is reporting 200W consumption, and the temperatures reach above 80°C.
If not, then continue to 250W limit and check the temps.
This is the process to determine if your cooler is working according to specifications.
If it's not, then remove it check for gaps and poor paste application etc.
If you find out that for example 250W is the maximum power your system can handle, then you can adjust the CPU settings to get as much performance as possible from that hard limit.
Undervolting, disabling HT and similar methods are common.
This is not necessary but could be the reason a benchmark is not high as what other people report for the same CPU and cooler.
NormanS_Intel
Hello StanZ,
Thank you for your response and I'd like to inform you that It is normal for the processor to throttle during a stress test because processors have two modes of thermal protection: throttling and automatic shutdown. When a core exceeds the set throttle temperature, it will begin to reduce power to lower the temperature. The throttle temperature can vary depending on the processor and BIOS settings. If throttling cannot keep the temperature down, such as in cases of thermal solution failure or incorrect assembly, the processor will automatically shut down to prevent permanent damage.
However, it is not normal for the system to throttle if there are no heavy applications running.
For additional information, you can check the following articles:
Norman S.
RobbieR_Intel
Hello StanZ,
I wanted to check if you had the chance to review the questions posted. Please let us know at your earliest convenience so that we can determine the best course of action to resolve this matter.
Robbie R.
StanZ
Hello all,
I have tried to limit the CPU Usage to 200W and then do a stress test, see image for the results. but in shot the CPU temps do again shoot up to 100c for some reason. I did not check at 250W yet but I think it will give the same results.
Are there any other bios setting i should look at.
Could it also be that the CPU goes in to safe mode (bug or feature) because the e-cores and the p-cores will have the same clock speeds so it does not crash it self or something in that guideline?
Kind regards,
Stan Z
StanZ
So I changed something else in the bios not only the first I had the long package duration power set to 200W but now i changed it so that the short package duration power is also set to 200W, the temps do rise slower and do not go all the way to 100c but still go to 90c - 95c so still pretty high
RobbieR_Intel
Hello StanZ,
I have sent you an Email, kindly check your inbox.
Robbie R.
