Hello, I am currently using an i7-14700k and I have drastic issues whenever I try to compile shaders within any game, it's either the message that I do not have enough Video RAM or if I start the game at least 3 times when it crashes I get a BSoD with the Error of "IRQL_NOT_LESS_OR_EQUAL", I've completely set my BIOS Settings to default and did a full reset of my OS. XMP does not work on my PC even though it should be supported with my DDR5 RAM.
Also have done Stress-Tests for my CPU & GPU with both on Full Throttle and no crashes at all, only happens with games.
I usually update all my drivers regulary and check the update-logs so it doesn't screw with my Hardware and clean it every 2 Months.
Also I have some mini-dump logs analyzed which somewhat indicate to Intel.
Specs:
Motherboard: Z790 AORUS ELITE X WIFI7
CPU: I7-14700K
GPU: GeForce RTX Super 4080
RAM: Kingston FURY Renegade 16GB DDR5 8000MT/s DIMM
Hello BSoD_Crash,
Thank you for reaching out to the community.
I’m sorry to hear about the issue you’re facing. To better understand and assist you, could you please provide answers to the following questions?
- Have you updated the BIOS to the latest version? If so, please provide the BIOS version.
- Have you updated your graphics drivers?
- Have you tried using the integrated GPU (iGPU) only?
Your response will help in diagnosing the issue more effectively. Let me know how I can further assist you.
John Sergio M.
Hello BSoD_Crash,
John Sergio M.
Hello BSoD_Crash,
John Sergio M.
