My PC setup:
CPU: Intel I5-6600K
cooler: Cooler Master Hyper 212 EVO
GPU: EVGA GeForce GTX 1070 Founders Edition 8GB
MOBO: Gigabyte GA-B150-HD3P - 1.0
SSD: Kingston HyperX FURY (120GB)
Issue example;
When i start Rainbow Six Siege, or GTA V my CPU usage goes to 100% in taskmanager... with as result that everything slows down, and even discord stops working.
I've tried to update drivers by windows update but it couldn't find updates
The drivers for your processor can be found here:
And, you can use drivers provided by gigabyte for your board.
Any other problems, you need to evaluate your system, specifically your OS version, any and all startups, remove all anti-virus products and use Windows Defender, and clean up your system.
You also need to check the requirements of the games.
Doc
Thanks for the reply,
I think my windows is the problem.
Windows is slow when I let windows defender scan my PC, (not normal slow but really slow) and the scans take far to long...
Also when I intall a driver I get the following meassage:
"The driver being installed is not validated for this computer. Please obtain the appropriate driver from the computer manufacturer"
Ill try to install a clean version of windows 10 and and reinstall drivers. Then wil try it again and let you know.
game requirements are good for my PC.
