Hello, recently i noticed my pc working very slow, after taking cpu-z test it shows its running core speed only 800hz- the multiplier is 8 and i cant change it in bios...
MSI Z170A gaming M5
corsair veangeance 8gb
radeon r9 390
samsung evo850 ssd
any one have same issue?
Hi Denisnord ,
Your CPU when is idle has multiplier 8x and when is in load it goes up to XX depends what CPU you have
Please try running the processor diagnostic tool available here:
https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool
Allan.
hello allan, i just run this test and this is the results
--- IPDT64 - Revision: 3.0.0.25.W.MP
--- IPDT64 - Start Time: 8/17/2016 7:40:30 PM
Processor 1
Intel(R) spbc Module Test
Module Version: 1.0.7.64b.W
Start Time: Wed Aug 17 19:40:30 2016
Test Result - PASS
..!!..Processor under test is verified as 'PRODUCTION'..!!..
Processor Manufacturer: GenuineIntel
Processor Brand String: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
End Time: Wed Aug 17 19:40:30 2016
Total Time: seconds: 0
Genuine Intel CPU Test
Module Version: 1.0.12.64b.W
Test Result - PASS
Expected: GenuineIntel
Detected: GenuineIntel
Temperature Test
Test Result - PASS
Expected: Greater than 1 degrees below max
Received: 75 degrees below max
CPU Brand String Test
Start Time: Wed Aug 17 19:40:31 2016
Test Result - PASS
Expected String Parts: As Defined in BrandString_LocalConfig.xml
Detected: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
End Time: Wed Aug 17 19:40:31 2016
CPU Frequency Test
Module Version: 1.0.14.64b.W
Test Result - PASS
Processor Name: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
Expected CPU Frequency: 4.00
Detected CPU Frequency: 4.00772
Expected Base Clock: 100
Detected Base Clock: 100.193
QPI link rate Test - Not supported.
Skipping QPI link rate Test.
End Time: Wed Aug 17 19:40:46 2016
Total Time: seconds: 15
Floating Point Test
Module Version: 1.0.10.64b.W
Start Time: Wed Aug 17 19:40:46 2016
Test Result - PASS
Million Floating Points per Second, MFLOPS: 115.2
Error: 0
--- Floating Point Test Passed!!!---
End Time: Wed Aug 17 19:40:48 2016
Total Time: seconds: 2
Prime Number Generation Test
Start Time: Wed Aug 17 19:40:48 2016
Test Result - PASS
Operation Per Second: 2.65832e+006
Error: 0
--- Prime Number Generation Test Passed!!!---
End Time: Wed Aug 17 19:40:50 2016
Cache Test
Start Time: Wed Aug 17 19:40:50 2016
Test Result - PASS
--- Reading Cache Size ---
- Detected L1 Data Cache Size --> 32
- Detected L1 Inst Cache Size --> 32
- Detected L2 Cache Size --> 256
- Detected L3 Cache Size --> 8192
Cache Size Test Passed!!!
MMXSSE Test
Test Result - PASS
--- Determining MMX - SSE capabilities ---
--- CPU FEATURES DETECTION FOR ---
--- MMX SSE ---
MMX - MMX Supported --> Yes
SSE - SSE Supported --> Yes
SSE2 - SSE2 Supported --> Yes
SSE3 - SSE3 Supported --> Yes
SSSE3 - SSSE3 Supported --> Yes
SSE4.1 - SSE4.1 Supported --> Yes
SSE4.2 - SSE4.2 Supported --> Yes
--- MMX SSE - capabilities check complete ---
MMX Test Result --- PASS
SSE Test Result --- PASS
SSE2 Test Result --- PASS
SSE3 Test Result --- PASS
SSSE3 Test Result --- PASS
SSE4.1 Test Result --- PASS
SSE4.2 Test Result --- PASS
AVX Test
Module Version: 1.0.11.64b.W
Start Time: Wed Aug 17 19:40:51 2016
Test Result - PASS
--- Determining AVX AES PCLMULQDQ capabilities ---
--- AVX/AES/PCLMULQDQ ---
AVX - Advanced Vector Extensions Supported --> Yes
AVX OS Support - AVX Operating System Supported --> Yes
AES - Advanced Encryption Standard Supported --> Yes
PCLMULQDQ - Polys Carry-Less Multiply Supported --> Yes
--- AVX AES PCLMULQDQ capabilities check complete ---
AVX Compare Test Result --- PASS
AES Test Result --- PASS
PCLMULQDQ Test Result --- PASS
End Time: Wed Aug 17 19:40:54 2016
Total Time: seconds: 3
IMC Test
Start Time: Wed Aug 17 19:40:54 2016
Test Result - PASS
--- Reading Memory Size ---
Detected Memory Size is --> 8.00GB
--- Subtest - Memory Size Test Passed!!! ---
--- Integrated Memory Controller Stress Test ---
Memory to be allocated = 1048576 byte
Memory Allocated.
Test 1 Ones and Zeros Moving Inversions write operations - Passed
Test 1 Ones and Zeros Moving Inversions verification operations - Passed
Test 2 32Bits Sliding Ones write operations - Passed
Test 2 32Bits Sliding Ones verification operations - Passed
Test 3 32Bits Sliding Zero write operations - Passed
Test 3 32Bits Sliding Zero verification operations - Passed
Memory Deallocated.
--- Subtest - Memory Stress Test Passed!!! ---
Integrated Memory Controller Stress Test Passed!!!
End Time: Wed Aug 17 19:40:55 2016
PCH Test
Module Version: 1.0.9.64b.W
Start Time: Wed Aug 17 19:40:55 2...
If you run an application, and keep CPU-Z on, the multiplier stays all time at 8x ?
yes, this is how i noticed its too slow, im playing league of legends and i had over 600fps before and now its barely 120 with droping to 30 in teamfight....
Go in control panel at power options and set it on High performance. You can manually set in advance power settings CPU power state and if you put on max 5% then CPU will stay all time on 8x ...
Maybe you or someone else changed something there and forgot.
Check if the slow mode booting switch is in the on position. Should be at the bottom of the motherboard, marked SLOW_1 it's meant for liquid nitrogen cooling which locks onto the lowest multiplier.
Do you still have same issue with the processor?
Allan.
