Processors
16281 Discussions
My new 9900k will not start into Windows on 8 cores, the 9600k in that board worked fine. If I only enable 6 cores on the 9900k it starts fine. even with 7 it freezes during startup. Getting into BIOS is not problem. Latest BIOS is installed
LHans3
AlHill
Windows 7 is not supported. Only windows 10 is supported on 7th gen and later processors.
Have you updated the bios on your motherboard?
Doc
LHans3
yes, its the latest BIOS and I run win10 pro 64 bit
AlHill
Are you certain your motherboard and bios supports the 9900K? What is the motherboard model number?
Doc
LHans3
Yes, it's the AORUS Z390 I pro wifi
AlHill
Well, either gigabyte support or one of the Intel support engineers will have to assist you.
Doc
LHans3
I will get another Z390 board in the next days, will check and confirm the CPU or the board is the issue ( But I tend to believe its the CPU, it was starting once with 8 cores, then crashed in Windows and never started again on all cores
n_scott_pearson
Have you tried reinstalling Windows?
