Community
cancel
Showing results for
Search instead for
Did you mean:
ВЯцен
My processor i3-3225 does not have one memory channel. Is there any way to fix this?
AlHill
It is likely a failure of your motherboard. Download and run this:
https://www.intel.com/content/www/us/en/support/articles/000005567/processors.html
Even if the processor is bad, your only option is to replace it, as the processor is not supported and discontinued.
Doc
ВЯцен
The effect is tested on three different motherboards
The result is the same
It seems necessary to change the processor
AlHill
Ok, so what do you want? The processor is discontinued, not supported, and out of warranty, and more than seven years old.
Get another processor that does work.
Doc
ВЯцен
I was hoping there was some way to repair the processor.
But it looks like I was wrong
