Processors
16133 Discussions
NUC11TNBi7 BIOS Update available?
SteveR2
Hi all,
Thought it would be a good idea to see if my NUC11 had a bios update available.
Not found on here on INTEL, went to ASUS and found similar ones but not a precise match.
Does anyone know if the nuc11tnbi7 running bios TNTGL357.0070.2022.1028.1209 requires updating?
Above details from running dmidecode.
The PC case is labeled SBNUC11TNHi7000.
Many thanks
S
n_scott_pearson
You have BIOS 70. The latest is BIOS 78. Here is download link for this update: https://dlcdnets.asus.com/pub/ASUS/NUC/NUC_11_Pro_Kit/TNTGL357.0078.zip?model=NUC11TNHI7. Inside this ZIP file, in subfolder TNTGL357.0078\One click BIOS Flash for Windows, you will find the executable for installing this BIOS starting in the Windows environment.
Hope this helps,
n_scott_pearson
Hope this helps,
SteveR2
Thanks Scott, I tried the link, it worked  well. Tried installing it but it said I needed to install 071 first. So I modified your link to point to the 071, flashed that then the 078 and all is well.
Many thanks
S.
pressed_for_time
Valued Contributor II
NUC11TNBi7 is the board number, the NUC is the the NUC11TNHI7 (that's i7 not 17) model. ASUS is providing support for it at this web page address .
See graphic below.
SteveR2
