Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
New Version of Security Unifier doesnt recognise my CPU
New version of Intel Security Unifier sais that my CPU is not supported.. yet i see it under the supported products - i5 5200U. I ended up lacking the drivers i need.. Any ideas how to fix this guys?
Highlighted
Community Manager
Hello aNdRi3,
What version of Windows are you using?
This is what is required to install and use the utility:
  1. A broadband Internet connection is required to use this utility.
  2. Operating system requirements for installation: This application installs on Windows* 7, Windows* 8, Windows* 8.1, and Windows® 10.
  3. We recommend that you perform a Windows update to bring your operating system up to date with the latest .NET.
Make sure you have the latest Intel® Management engine installed.
You can see more information here:
https://downloadcenter.intel.com/download/25952/Intel-Security-Unifier Download Intel® Security Unifier
Ivan
Highlighted
Community Manager
Got 50mbps internet connection, using Windows 10 with latest updates, got all net framework versions from 2.0 to 4.0, c++ from 2008-2015.
Highlighted
Community Manager
Please allow me to find out who can better assist you with this software.
Ivan
Community Manager
Hello aNdRi3 ,
After further investigation, I found out that the tool should only work on Skylake onward (6th generation CPU) and the reason it failed on your systems is because your processor is a Broadwell CPU (5th gen)
Ivan.
