ffmpeg crashes on my new i9-14900K / Ubuntu 22.04.4 with Segmentation fault error message.
Even after recompiling it specifically for my platform, it still crashes.
The machine is new with a newly installed and updated Ubuntu 22.04.4.
This does not happen on other machines also running a newly installed Ubuntu 22.04.4 with other processors.
Here is the whole output:
/usr/bin/ffmpeg -i 'input.mkv' -vcodec libx265 -crf 28 output.mkv ffmpeg version 4.4.2-0ubuntu0.22.04.1 Copyright (c) 2000-2021 the FFmpeg developers built with gcc 11 (Ubuntu 11.2.0-19ubuntu1) configuration: --prefix=/usr --extra-version=0ubuntu0.22.04.1 --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --arch=amd64 --enable-gpl --disable-stripping --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libdav1d --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librabbitmq --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzimg --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --enable-pocketsphinx --enable-librsvg --enable-libmfx --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared libavutil 56. 70.100 / 56. 70.100 libavcodec 58.134.100 / 58.134.100 libavformat 58. 76.100 / 58. 76.100 libavdevice 58. 13.100 / 58. 13.100 libavfilter 7.110.100 / 7.110.100 libswscale 5. 9.100 / 5. 9.100 libswresample 3. 9.100 / 3. 9.100 libpostproc 55. 9.100 / 55. 9.100 Input #0, matroska,webm, from 'input.mkv': Metadata: encoder : libebml v1.4.0 + libmatroska v1.6.1 Duration: 01:00:00.15, start: 0.000000, bitrate: 7678 kb/s Stream #0:0: Video: h264 (High), yuv420p(tv, bt709, progressive), 1920x1080 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default) Stream #0:1(eng): Audio: eac3, 48000 Hz, 5.1(side), fltp, 640 kb/s (default) Stream #0:2(eng): Subtitle: subrip Metadata: title : English Stream mapping: Stream #0:0 -> #0:0 (h264 (native) -> hevc (libx265)) Stream #0:1 -> #0:1 (eac3 (native) -> vorbis (libvorbis)) Stream #0:2 -> #0:2 (subrip (srt) -> ass (ssa)) Press [q] to stop, [?] for help x265 [info]: HEVC encoder version 3.5+1-f0c1022b6 x265 [info]: build info [Linux][GCC 11.2.0][64 bit] 8bit+10bit+12bit x265 [info]: using cpu capabilities: MMX2 SSE2Fast LZCNT SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2 x265 [info]: Main profile, Level-4 (Main tier) x265 [info]: Thread pool created using 32 threads x265 [info]: Slices : 1 x265 [info]: frame threads / pool features : 5 / wpp(17 rows) x265 [info]: Coding QT: max CU size, min CU size : 64 / 8 x265 [info]: Residual QT: max TU size, max depth : 32 / 1 inter / 1 intra x265 [info]: ME / range / subpel / merge : hex / 57 / 2 / 3 x265 [info]: Keyframe min / max / scenecut / bias : 23 / 250 / 40 / 5.00 x265 [info]: Lookahead / bframes / badapt : 20 / 4 / 2 x265 [info]: b-pyramid / weightp / weightb : 1 / 1 / 0 x265 [info]: References / ref-limit cu / depth : 3 / off / on x265 [info]: AQ: mode / str / qg-size / cu-tree : 2 / 1.0 / 32 / 1 x265 [info]: Rate Control / qCompress : CRF-28.0 / 0.60 x265 [info]: tools: rd=3 psy-rd=2.00 early-skip rskip mode=1 signhide tmvp x265 [info]: tools: b-intra strong-intra-smoothing lslices=6 deblock sao Output #0, matroska, to 'output.mkv': Metadata: encoder : Lavf58.76.100 Stream #0:0: Video: hevc, yuv420p(tv, bt709, progressive), 1920x1080 [SAR 1:1 DAR 16:9], q=2-31, 23.98 fps, 1k tbn (default) Metadata: encoder : Lavc58.134.100 libx265 Side data: cpb: bitrate max/min/avg: 0/0/0 buffer size: 0 vbv_delay: N/A Stream #0:1(eng): Audio: vorbis (oV[0][0] / 0x566F), 48000 Hz, 5.1(side), fltp (default) Metadata: encoder : Lavc58.134.100 libvorbis Stream #0:2(eng): Subtitle: ass Metadata: title : English encoder : Lavc58.134.100 ssa frame= 1 fps=0.0 q=0.0 size= 11kB time=00:00:00.92 bitrate= 97.3kbits/sframe= 86 fps=0.0 q=34.0 size= 11kB time=00:00:04.42 bitrate= 20.4kbits/frame= 163 fps=150 q=36.0 size= 11kB time=00:00:07.46 bitrate= 12.1kbits/frame= 224 fps=141 q=36.0 size= 226kB time=00:00:09.96 bitrate= 185.7kbits/frame= 287 fps=136 q=36.0 size= 226kB time=00:00:12.71 bitrate= 145.6kbits/frame= 347 fps=132 q=36.0 size= 226kB time=00:00:15.04 bitrate= 123.1kbits/frame= 412 fps=131 q=31.3 size= 256kB time=00:00:17.82 bitrate= 117.6kbits/frame= 476 fps=131 q=30.7 size= 256kB time=00:00:20.48 bitrate= 102.4kbits/frame= 548 fps=132 q=36.0 size= 512kB time=00:00:23.56 bitrate= 178.0kbits/frame= 617 fps=133 q=30.7 size= 512kB time=00:00:26.44 bitrate= 158.6kbits/frame= 680 fps=132 q=36.0 size= 512kB time=00:00:28.99 bitrate= 144.7kbits/frame= 739 fps=130 q=34.6 size= 512kB time=00:00:31.50 bitrate= 133.1kbits/frame= 800 fps=130 q=31.1 size= 1024kB time=00:00:33.96 bitrate= 247.0kbits/frame= 858 fps=129 q=31.1 size= 1024kB time=00:00:36.45 bitrate= 230.1kbits/frame= 915 fps=127 q=34.5 size= 1024kB time=00:00:38.76 bitrate= 216.4kbits/frame= 966 fps=126 q=33.8 size= 1024kB time=00:00:41.00 bitrate= 204.6kbits/frame= 1020 fps=124 q=30.8 size= 1024kB time=00:00:43.25 bitrate= 194.0kbits/frame= 1076 fps=124 q=34.3 size= 1536kB time=00:00:45.71 bitrate= 275.2kbits/frame= 1127 fps=122 q=33.2 size= 1792kB time=00:00:47.73 bitrate= 307.6kbits/frame= 1171 fps=120 q=30.6 size= 1792kB time=00:00:49.49 bitrate= 296.6kbits/frame= 1220 fps=119 q=33.2 size= 2048kB time=00:00:51.59 bitrate= 325.2kbits/frame= 1280 fps=119 q=29.9 size= 2048kB time=00:00:53.96 bitrate= 310.9kbits/frame= 1337 fps=119 q=33.0 size= 2560kB time=00:00:56.49 bitrate= 371.2kbits/frame= 1392 fps=118 q=31.1 size= 2560kB time=00:00:58.82 bitrate= 356.5kbits/frame= 1458 fps=119 q=33.1 size= 2560kB time=00:01:01.50 bitrate= 341.0kbits/frame= 1518 fps=119 q=31.6 size= 2816kB time=00:01:03.98 bitrate= 360.6kbits/frame= 1579 fps=119 q=35.6 size= 2816kB time=00:01:06.48 bitrate= 347.0kbits/frame= 1635 fps=119 q=30.8 size= 3072kB time=00:01:09.01 bitrate= 364.7kbits/frame= 1693 fps=118 q=29.2 size= 3072kB time=00:01:11.37 bitrate= 352.6kbits/frame= 1746 fps=118 q=34.1 size= 3072kB time=00:01:13.42 bitrate= 342.7kbits/frame= 1793 fps=117 q=32.6 size= 3328kB time=00:01:15.65 bitrate= 360.4kbits/frame= 1836 fps=116 q=27.7 size= 3328kB time=00:01:17.24 bitrate= 352.9kbits/frame= 1871 fps=115 q=29.3 size= 3840kB time=00:01:18.80 bitrate= 399.2kbits/frame= 1908 fps=113 q=33.3 size= 3840kB time=00:01:20.27 bitrate= 391.9kbits/frame= 1941 fps=112 q=29.4 size= 3840kB time=00:01:21.79 bitrate= 384.6kbits/frame= 1982 fps=111 q=27.1 size= 3840kB time=00:01:23.30 bitrate= 377.6kbits/frame= 2028 fps=111 q=35.6 size= 4352kB time=00:01:25.29 bitrate= 418.0kbits/frame= 2070 fps=110 q=31.6 size= 4608kB time=00:01:27.07 bitrate= 433.5kbits/frame= 2107 fps=109 q=31.0 size= 4864kB time=00:01:28.55 bitrate= 450.0kbits/frame= 2154 fps=109 q=35.4 size= 4864kB time=00:01:30.58 bitrate= 439.9kbits/frame= 2199 fps=108 q=33.1 size= 4864kB time=00:01:32.56 bitrate= 430.4kbits/frame= 2254 fps=108 q=32.5 size= 4864kB time=00:01:34.79 bitrate= 420.3kbits/frame= 2308 fps=108 q=28.8 size= 4864kB time=00:01:37.03 bitrate= 410.6kbits/frame= 2360 fps=108 q=30.0 size= 5632kB time=00:01:39.06 bitrate= 465.7kbits/frame= 2406 fps=107 q=31.1 size= 5888kB time=00:01:41.02 bitrate= 477.4kbits/frame= 2454 fps=107 q=31.4 size= 5888kB time=00:01:43.05 bitrate= 468.0kbits/frame= 2497 fps=107 q=30.2 size= 5888kB time=00:01:44.78 bitrate= 460.3kbits/frame= 2550 fps=107 q=28.9 size= 5888kB time=00:01:47.07 bitrate= 450.5kbits/frame= 2606 fps=107 q=31.7 size= 5888kB time=00:01:49.29 bitrate= 441.3kbits/frame= 2663 fps=107 q=29.3 size= 6144kB time=00:01:51.70 bitrate= 450.6kbits/frame= 2715 fps=107 q=33.9 size= 6656kB time=00:01:54.02 bitrate= 478.2kbits/frame= 2783 fps=107 q=34.8 size= 6912kB time=00:01:56.78 bitrate= 484.9kbits/frame= 2841 fps=107 q=32.3 size= 6912kB time=00:01:59.31 bitrate= 474.6kbits/frame= 2895 fps=107 q=31.0 size= 7168kB time=00:02:01.62 bitrate= 482.8kbits/frame= 2953 fps=107 q=29.1 size= 7168kB time=00:02:03.87 bitrate= 474.0kbits/frame= 3008 fps=107 q=36.0 size= 7168kB time=00:02:06.11 bitrate= 465.6kbits/frame= 3072 fps=108 q=36.0 size= 7168kB time=00:02:08.84 bitrate= 455.7kbits/frame= 3128 fps=108 q=36.0 size= 7168kB time=00:02:11.14 bitrate= 447.8kbits/frame= 3200 fps=108 q=33.0 size= 7936kB time=00:02:14.06 bitrate= 484.9kbits/frame= 3285 fps=109 q=33.0 size= 8192kB time=00:02:17.83 bitrate= 486.9kbits/frame= 3357 fps=110 q=34.6 size= 8192kB time=00:02:20.82 bitrate= 476.5kbits/frame= 3402 fps=110 q=33.4 size= 8448kB time=00:02:22.62 bitrate= 485.2kbits/frame= 3449 fps=109 q=32.3 size= 8448kB time=00:02:24.55 bitrate= 478.8kbits/frame= 3503 fps=109 q=34.6 size= 8448kB time=00:02:26.88 bitrate= 471.2kbits/frame= 3556 fps=109 q=36.0 size= 8448kB time=00:02:29.09 bitrate= 464.2kbits/frame= 3602 fps=109 q=29.3 size= 8960kB time=00:02:30.87 bitrate= 486.5kbits/frame= 3637 fps=108 q=34.1 size= 8960kB time=00:02:32.33 bitrate= 481.8kbits/frame= 3672 fps=108 q=34.4 size= 8960kB time=00:02:33.93 bitrate= 476.8kbits/frame= 3698 fps=107 q=31.1 size= 9472kB time=00:02:35.08 bitrate= 500.3kbits/frame= 3716 fps=106 q=33.0 size= 9472kB time=00:02:35.73 bitrate= 498.2kbits/frame= 3756 fps=106 q=33.2 size= 9728kB time=00:02:37.28 bitrate= 506.7kbits/frame= 3805 fps=105 q=28.7 size= 9728kB time=00:02:39.42 bitrate= 499.9kbits/frame= 3855 fps=105 q=31.7 size= 9728kB time=00:02:41.47 bitrate= 493.5kbits/Segmentation fault (core dumped)
Any idea where the problem is?
Many thanks for your time
Hello Keer
Thank you for posting in the communities. To be more familiar with your system, kindly please share with us your SSU Logs. You may download it at this link: https://www.intel.com/content/www/us/en/download/18895/intel-system-support-utility-for-the-linux-operating-system.html. Additionally, aside from the CPU, is there a specific difference between this machine and other system that is not experiencing the issue?
Ramyer M.
have you tried to encode different videos? and does this happens always at this point?:
....maybe there may be a frame or a set of frames that set the power consumption way too high, like CGI for example.
I would also try limiting the TDP on the CPU, as well a different build of the ffmpg and libx265
Hello Keer,
I am just following up about the logs of your system. I also noticed one of our community members asked a specific question in his post. Feel free to reply to us so we can try to help you. Thank you.
Ramyer M.
Hello Keer,
As we have not heard a response from you in the past days, we will proceed in closing this case. Should you need further assistance, feel free to post a new question as this thread will no longer be monitored.
Ramyer M.
