Processors
Processors (Intel® Core™, Intel® Xeon®, etc); processor utilities and programs (Intel® Processor Identification Utility, Intel® Extreme Tuning Utility, Intel® Easy Streaming Wizard, etc.)
12958 Discussions
New installed PC does not load OS. Motherboard or CPU?
RanaImtiaz
My New installed PC does not load OS, the first time I tried to build a new PC (I didn't install separate GPU,) Following are my steps:
  1. Installed New intel i5-10400 10th gen onto New MSI Z590-A pro Wifi motherboard. According the online doc: i5-10400 has integrated graphic card.
  2. Installed 16 GB RAM onto motherboard .
  3. On my personal macbook, Using balenaEtcher to flash Linux Lite image to USB
  4. Insert USB, Turn on my new PC.
It could load the BIOS interface. However, after I set to start from USB, then it loads start menu and I select to start Linux system, the screen turns to black and it says "can not find signal".
LeonWaksman
If you can see the BIOS screen, the problem is probably in your bootable USB.
Did you disabled the Secure Boot option in BIOS?
Leon
