hi.
I want To upgrade my HP Pavilion dv6 Notebook PC with another Processor im using now
an Pentium(R) Dual-Core CPU T4200 @ 2.00GHz (2 CPUs), ~2.0GHz need some Tips like witch CPU is a better
one that i can replace with this one.It have 4gb RAM, ATI Mobility Radeon HD 4530 512Mb. HELp mee !!
Thnx You Chayron..
The upgrade instructions are here along with supported CPU's
http://h10032.www1.hp.com/ctg/Manual/c01758220.pdf http://h10032.www1.hp.com/ctg/Manual/c01758220.pdf
freelance writer
freelance writer
A T9900 is the best CPU you can install in this machine , Have you ever install a CPU in a notebook before , It's about 130 secrew and about 6Hrs if you know what you are doing. P/S Make sure you shim it right or it will run Hot.
Topic Options
