Processors
14992 Discussions
Only half the threads and cores are being used i9 13900k
Risky
I have a i9 13900k which should display 24 cores and 32 threads in software like task manager but it only shows 8 cores 16 threads. This issue persists with the Intel® Driver & Support Assistant software which checked my system as well. Here are the outputs from the software's mentioned in the attached png files.
Risky
Sorry I meant half the threads are showing, and the incorrect amount of cores are being displayed in task manager and the intel support assistant scan.
Jocelyn_Intel
Hello, @Risky
Thank you for posting on the Intel® communities.
I will gladly assist you here, I appreciate the screenshots attached.
Please allow me some time to do some research on this. As soon as I have updates, I will let you know.
Jocelyn M.
Jocelyn_Intel
Hello, @Risky
Thank you for your time.
It seems to be an issue with Windows*, try resetting BIOS to default and the steps in the following article:
Why Does my System Have Fewer or Missing Cores?
Also, try the Intel® Processor Identification Utility and attach a screenshot to check the information displayed.
Jocelyn M.
Jocelyn_Intel
Hello, @Risky
I hope you are great.
I am checking this thread and I would like to know if you were able to perform the steps in my previous post.
Jocelyn M.
Jocelyn_Intel
Hello, @Risky
I hope you are doing great.
As we have not heard back from you, we will proceed to close this thread now. I hope you could see my last post.
If you need any further assistance with other matters, please feel free to contact us back and submit a new question as this thread will no longer be monitored.
Jocelyn M.
Risky
I managed to fix it, it seems that you need to activate the E cores in the bios which I didnt do originally. After that all the cores are now showing up in task manager. If anyone else has this issue do some digging in your bios and enable the E cores.
