Community
cancel
Showing results for
Search instead for
Did you mean:
MQuin11
PCIe shows as x0
I have an i3 6100 in a Biostar TB250-BTC motherboard. CPU-Z reports my PCIe speed as x0. I'm using a known-good GPU. I've also tried a second of the same main boards, and a G3900 proc I had on had. Can anyone think of a reason why these boards don't seem to recognize any PCIe lanes?
n_scott_pearson
Super User Retired Employee
Have you checked to see if there are any firmware (BIOS) updates available for this board. If so, install them and then test again...
Hope this helps,
MQuin11
I've tried all 3 BIOS available from the manufacturer
n_scott_pearson
Well, this could simply be a bug in the CPU-Z program, but I rather doubt it. You need to contact Biostar's customer support and have them report this issue to their BIOS engineers.
Community Manager
Hello FourLeaf,
I was reviewing this thread and I wanted to know if you resolved the issue or if you contacted Biostar?
Juan V.
MQuin11
I have contacted Biostar but they don't have a solution. I'm going to return both motherboards. It is odd that this same issue is on two boards both tried with 2 different processors.
