I tried searching for this answer but I am not that tech savy... If it is not capable of 64 bit and I wanted to upgrade the processor, how do I find out what is compatible with my motherboard?
I downloaded CPU-Z and says that
Name: Pentium 4 530
Code Name: Prescott
Package: Socket 775 LGA
Technology: 90nm
Core Voltage: 1.353 V
Specification: Intel (R) Pentium (R) 4 CPU 3.00GHz
Family: F
Ext. Family: F
Model: 4
Ext Model: 4
Stepping: 1
Revision: E0
Core Speed: 3000MHz
Multiplier: x15
Bus Speed: 200MHz
Rated FSB: 800MHz
L1 Data: 16kb 8way
Trace: 12Kuops 8way
Level 2: 8way
If you have an Intel Desktop Board, you can look whether they are on the list below:
http://www.intel.com/support/motherboards/desktop/index.htm
http://www.intel.com/support/motherboards/desktop/archive.htm
Identify your board firstly:
You can get the aa number and look for information on the internet.
Or you can check in the bios
Otherwise, use the intel motherboard identifier tool http://www.intel.com/support/motherboards/desktop/sb/CS-010687.htm Click Here
Then go to the specific motherboard website
Check for the supported/compatible processors.
You can get information of the CPU on the link below:
All the best,
Kind Regards,
Aryan.
The chip you have isn't capable.
http://processorfinder.intel.com/details.aspx?sSpec=SL7PU http://processorfinder.intel.com/details.aspx?sSpec=SL7PU
You need to know your motherboard to see what's compatable.
![](/skins/images/B7BA37F9CE4B52FF7CAE1FB0388839C8/responsive_peak/images/icon_anonymous_message.png)
