Processors
14536 Discussions
Performance comparison between Core i7-6900k and @Core i9-9900x using the following C ++ code.
SMoai1
 Source code:
void Function (BYTE * pdst, BYTE * psrc, BYTE dbit, BYTE sbit, int width, int height)
    INT_PTR i;
    INT_PTR size;
    size = (INT_PTR) width * height;
    for (i = 0; i <size; i)
        if (* (psrc i) & sbit)
            * (pdst i) | = dbit;
Compiler: VisualStudio 2010 64bit
result:
PC1: i7-6900k Measurement value: 125ms
PC2: i9-9900x Measurement value: 225ms
Although PC2 has higher CPU specifications, it takes longer than PC1 and I am wondering. Why does it look like this?
Thank you.
AlHill
Was this test done using the same motherboard, with the same memory and peripherals for both processors?
Doc
SMoai1
Thank you for your reply.
It is also different from motherboard, GPU and memory.
PC1: X99-E / WS                     NVIDIA1080     DDR4-2400 16GBx8
PC2: WS X299 PRO SAGE     NVIDIA2080s   DDR4-2666 16GBx8
AlHill
Well, I would not support such a comparison, unless on identical platforms.
You can compare the two processors here:
https://ark.intel.com/content/www/us/en/ark/compare.html?productIds=189124,94196
Doc
SMoai1
The memory and the supported chipset are different between i7-6900k and i9-9900x, so the motherboard and memory are different, right? The same environment is impossible in the first place.
I guess that the two CPUs handle the code differently, but I want to know the clear difference.
AlHill
if the chipsets and memory and motherboard are different, you are comparing apples and oranges.
That is the clear difference at this point.
Find a motherboard that supports both prcessors and test.
Doc
