Processors
All support for Intel NUC 7 - 13 systems has transitioned to ASUS. Read latest update.
14256 Discussions
Performance peak in GFLOPs for the Xeon
ZAlno
What is the peak performance in GFLOPs for the
Xeon E5-2650 v1 and E5-2697 v2
is there any table of comparison available to see
the performance peaks in GFLOPs for the Xeon E5 family.
Emeth_O_Intel
Thank you for contacting Intel Xeon Community Support.
I will double check this information, and as soon as possible I will be contacting you back in order to proceed with the next step.
Emeth O.
Intel® Server Specialist.
Emeth_O_Intel
Below are the Gigaflops (GFLOPS), Adjusted Peak Performance (APP), and Composite Theoretical Performance (CTP) values for Intel® Processors (32-bit and 64-bit). Find trade classification information for Intel® Microprocessors."
Look for the Xeon part, this should include the information your are looking for.
NOTE:
Emeth O.
Emeth_O_Intel
I would like to know if the information provided helps you to clarify your questions.
Please if you have more questions do not hesitate and let me know and I will be more than happy to assist you.
Emeth O.
ZAlno
Yes the table answered many of my questions. Thanks !
i have another question regarding the PCI-E x16 Gen3. I have Quanta STRATOS S210-X12MS rack and it have only one PCI-E x16 Gen 3 slot.
I was thinking about to upgrade the rack with Phi x100 cards ( specifically the Phi 7110p cards ). Can i upgrade the existing PCI-E slot with
PCI Express to USB Card like this one connected to 4 Phi cards through this USB solution.
If the PCI-E X16 Gen3 data lanes is to be splitted how mane lanes is required for each Phi x100 card connection ( each PCI-E X16 Gen3 lane is 2 Gbps connection speed ).
Will the system be able recognize all the cards as individual cards ready for computing tasks.
Best regards...
Emeth_O_Intel
Thank you so for replying back.
I was reviewing you question and unfortunately this specific configuration you are planning to acomplish is not supported or recommended by Intel. As a matter of fact, this specific component was discotinued on 2014.
On the other hand, if you are still planning to use those components my best recommendation will be to contact the server manufacture in order to verify the compatibility.
Emeth O.
Emeth_O_Intel
I am following up your thread and I would like to know if you have more questions.
If so, please do not hesitate and let me know and I will be more than happy to assist you.
Emeth O.
Emeth_O_Intel
I was reviewing your case and due to the fact that I have not seen any activity recently, I am going to proceed and close this thread. If you have more questions do not hesitate and contact us back and we will be more than happy to assist you.
Emeth O.
