Possuo Motherboard H55 Intel - Versão da Bios 2.6 ( 28/11/2018 ) ,
Intel® Core™ i3 CPU 550 @ 3.20GHz |
Microsoft Windows 10 Pro (64 bits) |
com 02 memoria ddr3 ( totalizando 4gb ), atualmente adquiri memoria kingston (KVR16N11/8 )
modulo de 8gb ddr3, entretanto ao retirar 02 modulos anterioir e plugar este de 8gb ddr3, apos ligar computador da erro na inicialização windows, que posso fazer pois memoria e compativel com M.B, caso seja atualização da bios, onde encontro mais atualizada ?
You have a 1st gen processor from 2010. It is discontinued and not supported on Windows 10.
Check with the manufacturer of the motherboard, which is likely NOT intel, for specs on their memory requirements.
Hello @Marcelsp
Por favor, informe-se que eu só posso apoiá-lo na língua inglesa. Eu usei uma ferramenta de tradução web para traduzir esta resposta, portanto, pode haver algumas traduções imprecisas.
We hope that the assistance provided by the community has been helpful.
Also, we would like to inform you that due to the Intel® Core™ i3-550 Processor and Intel® Desktop Boards (in case your system indeed has a motherboard from Intel) have been discontinued, Intel Customer Service no longer supports inquiries for it, but perhaps fellow community members have the knowledge to jump in and help. You may also find the Discontinued Products website helpful to address your request.
Andrew G.
