Processors
14794 Discussions
Poseo TUF FX504 y deseo instalarle una memoria optane de 32gb con ssd de 1tb (Memoria Optane H10) y mi pregunta es si funcionará, si son compatibles o qué me conviene hacer con el equipo para aprovechar esta nueva tecnología?
AGonz49
AlHill
You need to update your windows 10 to version 1809. Go here to do so: https://www.microsoft.com/en-us/software-download/windows10
You should make sure you have a backup of at least your data before doing so.
Regarding your bios, no, I cannot help you. This is why you need to check with your manufacturer regarding THEIR BIOS. Caution: Changing bios settings can result in you not being able to boot your device.
So, upgrade windows first, then contact your manufacturer to see if you have support for optane in the bios and, if so, how to change your bios settings.
Doc
AlHill
Does your TUF FX504 support optane memory?
Does your TUF FX504 bios have the required settings to support optane?
Does your processor support Optane?
What is your processor model number?
What operating system and version are you running?
Doc
AGonz49
I guess yes because it have ​a m.2 slot
BIOS version: 312​
GOP Version: 9.0.1075
EC version: R1.14​
CPU:​ i7 8750h
AlHill
Do not assume, because you have a m.2 slot, that optane is supported.
Your bios has to specifically support optane. You need to check your bios SATA mode and see what options you have. Provide this information.
You did not provide the OS and version. Go to start, settings, system, about, and look at the bottom of the page. Provide this information.
You really should check with the manufacturer to see if their bios supports optane.
Doc
AGonz49
SO Windows 10 Home Single 64 bits
SO version: 17134.706​
I dont know how to check​ BIOS sata mode. Could you guide me?
AGonz49
I ran this on cmd "systeminfo | findstr /I /c:bios" and found this: "BIOS Version: American Megatrends Inc. FX504GD.312, 13/07/2018"
AlHill
Doc
AlHill
Note: Even though it says American MegaTrends, the bios belongs to your device manufacturer.
Doc
