Processors
16137 Discussions
Power plan and Core usage
SureshRU
Hi Everyone,
Hope you are doing  great.
I will like to check whether is there any documents or information on the following:
Different Power Plans and Core Usage:
  • Battery Saver Mode (for Intel i7 13th Gen processor):
    • How many cores are active in this state  and how many are inactive to maximize battery savings?
  • Balanced Mode (for the same processor):
    • How many cores are active to maintain this state?
    • When handling heavy workloads, how many cores are allocated to effectively balance the load and optimize performance?
  • Best Performance Mode (for the same processor):
    • since the term best performance , believe all core must be in use. but it will be good if there is some article or breakdown
VARADHARAJAN
Valued Contributor I
SureshRU
Hi Varadharajan,
thank you for the reply, however i was not able to locate the correct technical document via the link provided.
do you have the exact link for that article ?
SureshRU
Hi Varadharajan,
you may ignore my previous comment.
found it.
