The screen stops giving image 3 seconds and returns, I have a i7 7700K, I did the test with Intel Processor diagnostic Tool and it's all right.
Frank3096: Thank you very much for joining the Intel® Processors communities. We will be more than glad to assist you in order to try to fix this problem.
The fact that the processor passed the Intel® processor diagnostic tool, indicates that it should be working fine and there are no overheating on the system.
Still the problem could be related to many different factors, could be the video cable, could be the board, could be the monitor itself or even the graphics driver. So, in order to better assist you we just need to gather a few details:
Did it work fine before?
What is the model of the motherboard?
Which type of memory RAM are you using? If it is possible, please provide the model of it, the size and the quantity of sticks you are using.
Which video port are you using?
Are you using adapters or converters?
Do you have the option to test the PC with a different monitor/TV?
Do you have the option to use a different video cable?
Which Windows version are you using?
Any further questions, please let me know.
Alberto R
Frank3096: I just wanted to check if you saw the information we requested previously and if you need further assistance on this matter?
Alberto R
These are the specifications of my PC:
Processor: Intel I7 7700K
Motherboard: Gigabyte Z270X-Ultra Gaming
Ram: Crucial Ballistix Sport 2400 16 GB DDR4 (1)
Power supply: Corsair CX 650 80 Plus Bronze
Operating system: Windows 10 64 bits
The video port is hdmi, but I'm using a DVI converter because the HDMI input of motherboard does not give image. I had the possibility to use another monitor but it does not support the HDMI format
Frank3096: No problem at all. Thank you very much for providing that information.
In order to try to fix this problem we can try to re-install first the chipset driver, then the management engine and after that graphics driver that are provided by Gigabyte, look for chipset and VGA:
https://www.gigabyte.com/Motherboard/GA-Z270X-Ultra-Gaming-rev-10# support-dl https://www.gigabyte.com/Motherboard/GA-Z270X-Ultra-Gaming-rev-10# support-dl
If the problem persists after that, since the processor works with Intel® HD Graphics 630, we can try the following driver, version 4729:
https://downloadcenter.intel.com/download/26941/Graphics-Intel-Graphics-Driver-for-Windows-15-46-?product=98909 https://downloadcenter.intel.com/download/26941/Graphics-Intel-Graphics-Driver-for-Windows-15-46-?product=98909
By any chance do you see a model or a part number on the DVI converter so we can check the specifications of it?
The fact that the HDMI port is not working could indicate a problem with the board itself. Do you have the option to test your processor on a different board or test your board with a different processor?
Alberto R
Alberto R
Frank3096: Thank you very much for letting us know those details. If you do not have the option to swap parts, in that case maybe there is a PC repair store close to you where they can do that for you. The other option will be to get in contact either with the place of purchase to check their warranty policy and verify if they can replace it or to contact Intel directly through our chat or phone support:
Chat support:
http://intelsupportchat.force.com/icslivechat/ics_tech_processor_ww_english_Chat http://intelsupportchat.force.com/icslivechat/ics_tech_processor_ww_english_Chat,
For phone support, depending on your location, you will see the contact information on the links below:
EMEA contact information: http://intel.ly/28QeAF3 http://intel.ly/28QeAF3
APAC contact information: http://intel.ly/1ITfjUF http://intel.ly/1ITfjUF
LAR contact information: http://intel.ly/29c0rW4 http://intel.ly/29c0rW4
North America: Phone Number 1-916-377-7000, Monday - Friday 7:00 AM to 5:00 PM (Pacific Time).
Alberto R
