Processors
14780 Discussions
Problem turning on Desktop after installing Intel Active Monitor
I was asked to solve a problem with a computer having a Pentium 4 prescott 2.7 Ghz, when I installed the latest version of Intel Active Monitor to check some features and temperature, right after cliking on "Next" button the computer turned off, When I tried to turn it on again it didn´t boot, and the Power LED was yellow instead of Green, and starts making a LOT of noise ( I believe such a loud noise must come from the hard drive but im not sure). Any solution for this strange problem?
Salem_W_Intel1
Hi!
If your board's an Intel(R), I'd recommend referring to the following website and follow the suggestions there (those that are aplicable to the scenario you describe):
http://www.intel.com/support/motherboards/desktop/sb/cs-010254.htm
