Processors
14516 Discussions
Problem whit intel i7 9750H
ZakZ
can someone help me? I have an Acer predator helios 300 2019. My processor is running 74 degrees celsius and I'm doing nothing. Usually is like 40 degrees celsius. What I must do to repair this? Is any program... Thank you!
Sebastian_M_Intel
Hello ZakZ,
Thank you for posting on the Intel® communities.
1. Run the Intel® System Support Utility (Intel® SSU) and attach the report generated:
  • Open the application, check the "Everything" box, and click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
  • Click on the menu where it says "Summary" to change to "Detailed View".
  • To save your scan, click on "Next", then "Save".
  • Use the option under the reply window to attach the report to the thread (Drag and drop here or browse files to attach).
2. Run the Intel® Processor Diagnostic Tool and send the results either in a screenshot or .txt file. To save the report, once the test is done, click on "File >> View Results File" and attach the .txt file to your reply.
3. While your system reports 74°C, provide a screenshot of the Task Manager. Also, please include the report that shows you these temperatures.
4. Did your system work before? If yes, do you remember making any changes before the issue started?
Sebastian M
Intel Customer Support Technician
ZakZ
thank you i found the google crome has 90 procents ussuage of my processor.
Sebastian_M_Intel
Hello ZakZ,
Thank you for your reply.
Does it mean that you found the cause of the issue and could fix it? Otherwise, can you please provide the information requested previously?
Sebastian M
Sebastian_M_Intel
Hello ZakZ,
Were you able to check the previous post and get the information requested? Please let me know if you need more assistance.
Sebastian M
ZakZ
Hello Sebastian M,
Thanks for your help! The guilty was Chrome.
Zak Z
Sebastian_M_Intel
Hello ZakZ,
Thanks for the update.
Based on that, we will close this inquiry. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Sebastian M
ZakZ
I solve the problem its nothing wrong whit the processor! I found that the chrome browser was doing something in the background. And I solve that problem too. So thank you for your help!
Zak
