Hi guys i just assembled my rig. It has the following configuration Core i5 2500k,Intel DH67BL MOBO, 4 GB RAM, and Galaxy GT 430 GPU, Huntkey 550W SMPS, Windows 7 ultimate 64 bit,Cooler master CM 690 II advanced.The problem that i am facing today is that one of my CPU core always runs at 100% even if there is no program is running at the background. Why is this happening i have run a virus scan with the AVG Free edition there was no infection and updated the video driver,Updated the BIOS and all other drivers still facing the same problem so i changed my operating system to Kubuntu 10.10 still faced the same problem hence i once again changed my OS to Windows XP SP3 still faced the same problem so guys what should i do now.
Thank you.
Try the processor on a 2nd fully supported motherboard to see if the processor causes the same behavior.
If that is the case, then you can contact the Intel support line at:
http://www.intel.com/support/9089.htm http://www.intel.com/support/9089.htm
