Processors
16284 Discussions
Problema E5800 - Problem with E5800
Ciao a tutti, ho recentemente cambiato processore , passato da E5300 a E5800. Ho questa scheda madre, ASUS p5kpl-AM e con alcuni giochi avevo degli scatti improvvisi, ho fatto i test del processore, tutti e 2 senza problemi. Bios aggiornato, come potrei risolvere? Devo cambiare scheda madre? Fatemi sapere, grazie.
Hi, i recently changed my processor, from E5300 to E5800, and i have this motherboard, Asus p5kpl-AM, and playing some games it freezes, i did some processors test from download section, and everything appears ok. I updated the bios too, What i should do? Do i have to change my motherboard? Let me know it, thank you.
Adolfo_S_Intel2
I would suggest making sure that the motherboard is fully compatible with the E5800, please check the following website for compatibility information between your motherboard and our processors.
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us
If the processor is not listed as supported, it will not work properly. We strongly recommend installing a fully supported processor for your motherboard.
I would like to change motherboard, but i'm not finding anyone that supports that, is this possible?
If you check the voltages in the bios you will find one of them in red and this is your problem. the board does not support the cpu. hope this helps. sat009
Nothing is red in my bios, but i write here all the value, you can say me if something is wrong.
Plug and play : Yes
PCI latency 64 (is it right?)
IRQ to PCI VGA YES
palette snooping yes
CPUMATP settings enabled
C1E support enabled
max cpuid value limit enabled
cpu tm function enabled
execute disable bit enabled
memory remap feature enabled
configure dram timing by spd enabled
initiate graphic adapter peg/pci
internal graphics mode select 8 mb
peg force X1 enabled
audio controller azalia
front panel hd audio or avrack97??
serial port 1 address 3F8 IRQ 4
parallel port address 378
parallel port ECP
ECP DMA3
Parallel .... IRQ7
onboard pcie lan enabled
lan option rom dsiabled
cpu temperature 32,5 / 90 F
Motherboard 31/87F
cpu fan speed 2205 rpm
chassis N/A
power fan N/A
VCORE 1,304V
3,3 V voltage 3,328 V
%v 5,196 V
12V 12,144V
ata/ide config enhanced
enhanced mode support S-ATA
ide detect 35
configure system freq/voltage
ai overclocking auto
dram auto
memory over auto
1,25 auto
VTT cpu auto
1,5 auto
Vcore auto
is it evreything ok?
