Processors
16276 Discussions
Problema con Pc nuevo
Buenas, acabo de comprarme todas las piezas para mi nuevo pc, una vez he montado todo al darle al boton de Power se enciende durante 2 segundos y se me apaga, he probado con otra placa y pasa lo mismo por lo que me llega a dar que es la CPU
Placa Base: Z77A-G45
CPU: Intel 3rd Generation Core i5-3570K CPU (4 x 3.40GHz, Ivy Bridge, Socket 1155, 6Mb L3 Cache, Intel Turbo Boost Technology 2.0)
GPU: Asus nVIDIA 3D GeForce GTX 560 TI DirectCu II TOP Graphics Card (1GB)
PSU: Corsair CMPSU-700GUK Gaming Series GS700 High Performance 700W Power Supply
RAM: Corsair CMZ8GX3M2A1600C9 8GB 1600MHz CL9 DDR3 Vengeance Memory Two Module Kit
He probado de montarlo solo con CPU y una de RAM y no pita ni hace nada, 2 segundos y se apaga, los pines de la placa base estan todos Ok...
Cualquier sugerencia, ayuda es bienvenida.
Saludos
Adolfo_S_Intel2
Since you have tested on 2 different motherboards, make sure the 2nd motherboard is fully compatible with this processor, if that is the case, then it seems to be a defective processor, so at this point if you purchased the processor less than 30 days please proceed to contact the place of purchase for warranty options.
If you purchased the processor over 30 days ago, then I would suggest contacting the local support center for your area so they can assist you with any warranty option.
You can find the contact information for closest support center at:
http://www.intel.com/support/9089.htm http://www.intel.com/support/9089.htm
You can also open a chat session at:
http://www.intel.com/support/feedback.htm?group=processor# processor http://www.intel.com/support/feedback.htm?group=processor# processor
