Ho acquistato un processore i5-11400 e mi si presenta il seguente problema:
- Non vengono visualizzati correttamente i QR code (WhatsApp Desktop e altri). Essi sono incompleti e quindi non leggibili.
Cosa posso fare per risolvere il problema?
Grazie.
Alessandro
I bought an i5-11400 processor and I am presented with the following problem:
- QR codes are not displayed correctly (WhatsApp Desktop and others). They are incomplete and therefore not legible.
What can I do to solve the problem?
Thank you.
Alexander
Hello AlessandroP
Thank you for posting on the Intel️® communities. Please share with us the Intel® System Support Utility (Intel® SSU) results
- Download the Intel SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
- Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
- Click on the menu where it says "Summary" to change to "Detailed View".
- To save your scan, click on "Next", then "Save".
David G
Hola, también tengo un i5 11400 y presento el mismo problema, en un grupo de facebook alguien publicó que tiene ese problema, le comenté que yo también lo tengo, ambos tenemos el mismo procesador y usamos los gráficos integrados, en el momento en que escribo esto, somos 5 personas en la misma publicación con este mismo problema, todos tenemos algo en común, tenemos un i5 11400, adjunto el resultado del escaneo Intel SSU
Hello @AlessandroP
@CristianSantos make sure your system is up to date and if the issue persists, please open a new thread with all the information.
David G.
David G.
Hi, try this.
Disable intel UHD Graphics > reload the QR code > scan QR Code > enable intel UHD Graphics
