Processors
14537 Discussions
Problemas con el I9 9900k se estanca a 800 Mhz
AndresMC80
Buenas tardes, tengo un problema con mi procesador es un i9 9900k, el normalmente funciona a 4.7 Ghz pero ahora se estancó en 800 Mhz y no pasa de ahí, he revisado la refrigeración y funciona, el bios lo detecta a 4.7 Ghz. No se que puede ser, alguien que me pueda ayudar.
Muchas gracias.
Alberto_R_Intel
AndresMC80, Thank you for posting in the Intel® Communities Support.
Just to let you know, we only provide support in English language and currently, we are using a translation tool.
In order for us to provide the most accurate assistance on this matter, we just wanted to confirm a few details about your system:
When did you purchase the Intel® processor? (For Warranty Purposes)
What is the model of the motherboard?
Did you build the PC?
When did the issue start?
Did you make any recent hardware/software changes that might cause this issue?
Which Windows* version are you using?
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91600
Albert R.
Alberto_R_Intel
Hello AndresMC80, I just wanted to check if you saw the information posted previously and if you need further assistance on this matter?
Albert R.
Alberto_R_Intel
Hello AndresMC80, Since we have not heard back from you, we are closing the case, but if you have any additional questions, please post them on a new thread so we can further assist you with this matter.
Albert R.
