Buenas tardes, tengo un problema con mi procesador es un i9 9900k, el normalmente funciona a 4.7 Ghz pero ahora se estancó en 800 Mhz y no pasa de ahí, he revisado la refrigeración y funciona, el bios lo detecta a 4.7 Ghz. No se que puede ser, alguien que me pueda ayudar.
Muchas gracias.
AndresMC80, Thank you for posting in the Intel® Communities Support.
Just to let you know, we only provide support in English language and currently, we are using a translation tool.
In order for us to provide the most accurate assistance on this matter, we just wanted to confirm a few details about your system:
When did you purchase the Intel® processor? (For Warranty Purposes)
What is the model of the motherboard?
Did you build the PC?
When did the issue start?
Did you make any recent hardware/software changes that might cause this issue?
Which Windows* version are you using?
Albert R.
Hello AndresMC80, I just wanted to check if you saw the information posted previously and if you need further assistance on this matter?
Albert R.
Hello AndresMC80, Since we have not heard back from you, we are closing the case, but if you have any additional questions, please post them on a new thread so we can further assist you with this matter.
Albert R.
